How can connect and display Lotus data in SharePoint?
How can I connect and display non-email Lotus data by setting up share point? If any tool, applications or training is required to do this please inform me. I am not sure about xml which can be used for this. I am not an expert in Lotus.
Answered By 0 points N/A #103111
Hello friend.
On your Lotus System, you have to create an account through share point for data set up. you don't need to be an experts. but good command over setting is required. You can try by xml file to convert doc. by using converter. this going happen to serve you.
1. Share point or outlook account needed.
2. Sync it before working.
3. Transfer data or email.
About sync: after creating your account from outlook and share point. Log in Press right mouse button and click sync from your PC. You must have a converter providing file convert.
Hope you can solve your problem
Thanks
