bappyrb
10 points
Posted on - 09/25/2011
How can you upload file your server Networking work needed?
How can file Upload server
The most common way to upload the files to your hosting server is FTP(File Transfer Protocol).
Fist,You have to install FTP client like CuteFTP,FileZilla etc
You can download this software here – Client Download. Download it and install it on your computer.
Run FileZilla Client installation file and follow the installation instructions.
First of all  you must add your website information: Go to File – Site Manager:
Click on New Site button and add required information in General folder:
1-Host – hostname of your website
2-Servertype – mostly FTP – File Transfer Protocol
3-Logontype – Normal
4-User – your username
5-Password – your password.
Click on OK button to save the changes.
Now information about your site are stored.
You can connect your website (server) now.
Click on File – Site Manager, Select your site and click on Connect button.
Uploading or downloading files:
You are now connected to your server.
On the left side of client, there are files which are saved on your personal computer.
On the right side of client, there are files which are saved on the webserver.
Click the right mouse button on file(s) on the left side of client and select Upload.
Your file(s) will be uploaded to the server.
Click the right mouse button on file(s) on the right side of client and select Download.
Your file(s) will be downloaded to your computer.
The most common way of uploading something to your web server is through FTP using an FTP application. If you are planning on installing an FTP client application then might as well consider downloading FileZilla.
FileZilla Client is a fast and reliable cross-platform FTP, FTPS and SFTP client with lots of useful features and an intuitive graphical user interface. It has features like:
Easy to use
Supports FTP, FTP over SSL/TLS [FTPS], and SSH File Transfer Protocol [SFTP]
It runs on Windows, Linux, Mac OS X, BSD, and more
Supports IPv6
Available in different languages
Supports resume and transfer of large files greater than 4 GB
Tabbed user interface
Powerful Site Manager and transfer queue
Bookmarks
Supports drag & drop
Supports FTP-Proxy, HTTP/1.1, and SOCKS5
Synchronized directory browsing
The latest stable version of FileZilla Client is 3.5.3. To download FileZilla Client 3.5.3, You may visit. This version works with Windows XP 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, Windows 7 32-bit and 64-bit, Linux, and Mac OS X 10.5 and later See this also.
