How can find a effective volume booster blackberry?
In my blackberry phone I want to increase the volume more while playing music. Is there any way for it? Is there any good volume booster blackberry? I need instructions for that apps too.
Hello Elin Ortie,
Blackberry Smartphones have an inbuilt feature to amplify audio volume. To activate the option please follow the steps below :
> Click Media icon from your BlackBerry's home screen
> Press Menu key
> Select Options or Media Options (depending on your model)
> Check Audio Boost box or select the On option for Audio Boost (depending on your model)
> A warning screen will appear. Read it and click Yes to proceed.
> Again click the Menu key and press Save.
This will increase your Blackberry's volume significantly. Also play high quality 320kbps audio files for optimal music experience. Hope this helps.
Best regards.
Notifications
