How Can I Access My Router Remotely: Steps To Follow.
I have all the important work files in my computer at the office. I want those files at home too. So, how can I access my router remotely?
Step 1: Click on the Start button. Select the option of Computer and then Properties.
Step 2: Select Remote Settings.
Step 3: Enter password.
Step 4: Choose one of the options under Remote Desktop.
Step 5: Click on Select Users.
Step 6: Select Add in Remote Desktop Users dialog box.
Step 7: In Select Users, click on the option of Location and choose which place you want to search.
Step 8: Type the name of the user in Enter the object names to select and then click on OK.
Step 9: Now check the name of the user in Remote Desktop Users dialog box and select OK.
