I am unable to access Nvidia control panel. I installed an Nvidia graphics card, but I cannot see the Nvidia Control panel in the Start menu. Right-clicking on the Desktop also did not display the Nvidia Control Panel option. Please help me through the process.
How Can I Access Nvidia Control Panel In My Dell Laptop?
Since you have recently installed the Nvidia graphics card, I think you do not have the required drivers. That’s why you are unable to access Nvidia control panel.
Method 1
a. Go here
b. Enter your product details.
c. Click on Search.
d. You will get the required drivers.
e. Go to the supported products tab and read the specifications
f. Download the drivers.
g. Agree to the terms and conditions.
h. Once the download completes, restart your device.
i. Right-click on your desktop.
j. You will find the Nvidia Control Panel.
Method 2
a. Press Windows+R on your keyboard.
b. Type control and press enter.
c. Double-click on Nvidia Control Panel.
d. Click on the Desktop Dropdown Menu.
e. Enable “Add Desktop Context Menu.”
f. You will be able to get the control panel as mentioned in the guide book.
