How can I access the project web through the internet?
Hi Experts,
How can I access the project web through the internet?  I had Project Server 2007 installed in my Windows 2003 server which works in local network.  But when I tried to connect it with local IP address of server it won’t work. Can you please suggest of what’s the right thing to do? Any help ? Thanks!
Answered By 80 points N/A #98175
Hi Scowle,
A pleasant day to you. Actually, you can't really access your project web through the net. There's a restrictions in requesting local process (for example: http://localhost or http://127.1.0.1  etc.). I suggest you to use IIS instead of using local IP.
To install IIS on your windows 2003, follow the step by step procedures below:
  • Go to start > control panel > and click add remove program.
  • Click add/remove programs in windows component
  • Choose Application server in windows component wizard under components
  • Hit next and then click finish after the wizard completes the installation
REMINDER: It is not necessary for certificate services which includes components in selecting application server to perform a default installation of the IIS  (Internet Information Services).
-Zorian
