How can i access vbulletin change user name feature?
I have got issues with my current username, I need someone to direct me to the vbulletin change user name feature, so I can change my username. Am just a member not an administrator.
As a member or even a moderator you can't change your username , only administrators can.
If you really need to change the username you can either contact the admin and ask him to change the username for you and explain your reasons or you can contact [email protected] and ask for a new username.
Hello Aubrielillian,
You can’t change your username. Only admin can do it. If you are not a member, you can’t do it. Yet, there is no feature to change the username in vbulletin.
Get upset? Oh Man. Just cheer up. If you need to change the username urgently, you can contact with the admin. Because, only a admin can change the username. This may help you.
Hope a better day.
