How can I add multiple languages in Firefox
Hi all,
I used to write multiple dictionary languages in the mails. I want a spelling checker to check whole thing. I have one spell checker and an add-on to switch the dictionaries.
But sometimes it does not work properly. Some places it works and some of the places its not working. I want a merged dictionary by using which Firefox can check spelling in multiple languages without switching between dictionaries. It has to add to my Firefox.
Is there any software that can do this? Please someone suggest me a way out. Thanks a lot in advance, guys!
Answered By 0 points N/A #193775
Solution. To install a language pack in Thunderbird, do not click the link to the xpi file. Instead, open Thunderbird's Extensions or Add ons window, then drag the link from your browser and drop it there. Alternatively, save the Xpi file on your computer and install it in Thunderbird later.
If you are using the most recent shipping release, the quick path to the language pack .xpi file is:
Otherwise, to download a language pack for your release:
  1. Go to: http://DOWNLOAD.cdn.mozilla.net/pub/mozilla.org/
  2. Go to the directory there for the Mozilla application you want to change—for example: thunderbird
  3. Go to the releases directory.—for example: thunderbird
  4. Go to the directory for your release
  5. Go to the directory for your operating system.
  6. Go to the Xpi directory there.
  7. Install the Xpi for the language, or language and region, that you want.
