How Can I Add Pdf Printer To Windows 7?
I am the user of a Windows 7 computer and want to add a new printer for pdf uses. How can I add pdf printer to Windows 7?
To install a pdf printer manually, follow the steps below: Go to the devices and printers option through the control panel, from the start menu. Click on add a printer and then from the options shown, select “local printer” For the source, check Use an existing port. In the dropdown menu, select Documents*.pdf (Adobe PDF) Now, click on the button named “have disk” and click “browse”. Go to C:Program Files (x86)AdobeAcrobat 10.0AcrobatXtrasAdobePDF. A list will be displayed.
Click AdobePDF.inf and hit OK. From the given adobe pdf converters, choose the 6th one. Name your new printer and follow the prompts correctly to install the printer.
