How can i add a $ symbol in excel cell
Hi All,
I am trying to add a $ in a cell but it just disappears.
Thanks
Hi All,
Thanks
Hello E.Robe.
I just read your question about inserting $ symbol into excel cell. Robe, it’s very simple to insert symbol into spreadsheets, please follow these steps to insert your desired symbol into any cell in excel spreadsheet.
First of all, select your desired cell, where you want to insert symbol.
Now, click on insert tab in Excel.
You will see symbol button in this tab, click there.
Upon clicking on symbol button, symbol directory will be opened, now find your desired symbol and finally click on insert. Your desired symbol will be inserted into cell.
I hope with this your issue is resolved.
1) you just press right click on specified cell
2) press [format cell], Â
3) number, currency button
4) symbol $ Â and also select you desire nagative number.
must be check symbol $ sign
Hi Robe,
Hi E. Rode,
I have read your posting about your question regarding on how to put a dollar sign ($) to excel cell. I'll be more than glad to help you work this out. What I can do for you right now is to forward to you a couple of instructions and it will also serves your guideline. Here I attached a coherent sample on how to put a dollar sign on excel cell.Â
2. After clicking the Symbol tab, the second screenshoot above will be the output. The dollar sign appears at the fifth column of the first row. Then click Insert button below then click the Close button.
3. This will be the result.
I hope this guide will help you thoroughly.Â
Have a great day!
Hi, welcome you in techyv.com. Here you can find out more information what you need everyday.
Here is your questions answare..
 1. open Excel
 2.Then visit 'HOME'
 3. Here you see $ symbol.
 4. Click beside the $ symbol
 5.select the box where you want to give $ symbol
 5. select $ symbol
 6. write some number it should be see like $ 7…
 hope it will be work… thank you.
You can put whole functions into the DOLLAR function, like this:
=DOLLAR(SUM(A1:A4), 2)
You can also use cell formatting on the cell in question (Format – Cells, the Number tab, choose Currency).
