I have download get audio associated with MP3. Now, I want to open this program automatically when I click on an MP3 icon. I have made the option "Always use this program for this type of file", but it always asks me. What can I do?
How can I automatically open mp3 with jetaudio association?
Dear Robert,
Your problem can occur for several reasons. Most common of them are as follows-
i) Trial version of jetaudio.
ii) Incomplete installation.
iii) Personal settings that inhabit full activities of jetaudio.
iv) Not restarting computer if necessary.
You can solve this problem by following the steps below-
i) Select the item.
ii) Click right button.
iii) Select open with.
iv) Select choose a default program.
v) Select your program (in this case jetaudio).
# If your program does not show in the dialog box then select browse. Find your program.
vi) Click always uses the selected program to open this kind of file.
vii) Press OK.
If this does not work then
i) Select your item.
iii) Select properties.
iv) Change opens with.
If both of this fails then uninstall jetaudio. Restart your computer then re-install jetaudio.
Hi Robert martin,
For automatically open mp3 with jetaudio association:
Go to Start> Set program Access and Defaults> Custom >
Then you mark Check in Use my current media player >
and uncheck the enable access to this program for windows media player.
You can use the file extensions, like asx avi mp3 way aif
Try to download jetAudio. It must be helping you out:
Enjoy:
