rajib
20 points
Posted on - 08/21/2011
My computer is Dual core configuration. Now I face one problem. I can not open my PC and it is about error code. when I open my computer then open one message and it showing error – code 80072f8f. I do not understand why this message is showing. I check every connection of my PC.
Now what can I do?
Please help me.
How can i avoid error code?
Dear Rajib,
I hope you are fine and enjoying your life. The question you have asked is not clear enough, to actually understand the problem. But as you have mentioned that, it’s an anonymous error code coming, which is preventing you to open your system. I think your system has encountered a problem in your Operating System (windows or whatever you are using). Your system is not booting perfectly, that is why you are facing the problem. I would suggest you two things in order to fix your problem.
Repair your windows through a bootable disk, using the Windows Repair prompt Or in case it does not work
Re-install your Operating System. That’s the best thing to do.
I hope you would consider these suggestions.
Thank You
Abbie1
Hi Rajib,
Well first of all your question is a bit ambiguous. The best way to ask is that along with you error – code 80072f8f also mention the message appeared. As this error code is occurred because of many reasons. There might be a possibility that your date and time is not set properly.
Please correct if that was a reason. For changing date and time please double click the time displayed area at task bar.
Please see image one and perform steps one by one to resolve this issue.
Regards.
