How can I avoid local IP tracking?
Do proxy servers really do a great job in preventing local IP tracking? Or can you suggest any program or software that I can download to avoid this? Any answer would be a great help.
Proxy servers are usually ran by intruders, so it would not be totally safe to use those. You may want to purchase a program by the name of "HideMyIP2009" instead. This will change your IP address to a fake one.
Answer:
Most of the ISP provides static IP addresses which can be tracked very easily. So following  are the few easiest ways to avoid local IP tracking.
1. Always use anonymous proxies which hide your identity and uses dynamic IP’s which is always hard to track.
2. Change user agent frequently which provides your basic information to the severs. It also shows that from which operating system you are connected.
3. Never allow cookies, go to your browsers security settings and turn it off as long as you are surfing.
4. Do not click suspicious or fake links.
5. Use proxies servers which makes you anonymous on IP world.Â
