How Can I Calculate Distance Between Two Cities?
Hi, I am a guy planning my very first solo road trip. I will be traveling to many cities, including Manhattan and Chicago. I need to know how I can calculate distance between two cities, so I can plan the trip better.
Answered By 0 points N/A #111258
Hi, congratulations on deciding to go on a solo road trip! It’s going to be memorable for sure. For your help, you can calculate the distance between two cities using the distance calculator, the link to which is given below:
http://www.distancesfrom.com
What you need to do, is enter the start point and the end point and it will show you the exact distance you need to travel. In addition, it will also show the travel time, the longitude/latitude information and much more!  
