ronyb
20 points
Posted on - 04/16/2012
Please tell me the way in which I can calculate automatically in Microsoft excel? I have to calculate many data in Microsoft excel.
mdhosain
How can i calculation in Excel automatically?
Automatic calculation in Excel-
You can easily sun your data via Microsoft Excel. To get this you are doing not got to input formula to get it, as a result of it is terribly time consuming method. You will simply head to your result by below short method in terribly short time.
Follow the directions:
At the first open an Excel spreadsheet for this task. Then input the data within the cells. Then you would like to try to highlight the cells keeping the data which be totaled, and therefore the total is calculated for you. Take a glance within the status bar across a bottom of Excel spreadsheet.
If you are doing not have a status bar across bottom next go to view menu plus check the status bar choice. You will use this feature all occasion if you want the total for an additional worksheet or report, or simply a fast inspects the entire.
For instance, during a billing spreadsheet during which every data is on its personal line, I will highlight all the cells keeping the data to get a fast total of the data therefore the total is already calculated, we tend to do this month.
Thanks to techyv.com and the expert who solved the problem. Since I am a newbie user of MS Excel I am not much used to its components. I appreciate the effort put by the expert (Mdhosain) and am very thankful for the help.
