How can I carry out a MacAfee cleanup after uninstallation?
I have been using AVG Pro Antivirus 2012 and at some point a has a problem with it stopping all installations and rejecting any settings allowing installation of applications.
I decided to change to McAfee Antivirus 2012 which served me well.
I have purchased AVG Professional 2013 and this is what I would like to switch to.
I have tried to uninstall the Antivirus but it is not getting cleaned out fully.
Is there an application that I can use for McAfee cleanup to completely remove the files, folders and any registry information?
