Harold Rudy
50 points
Posted on - 05/03/2013
Hallo there!
I have this XBox 360 which has all along functioned very well without any hitches. However, it recently it has not been showing any videos or producing any audio. I would like to carry out a Reballing, but it is very expensive using the special Reballing tools. Is there a way of Reballing without special tools to make it a little affordable for me? Thanks.
How can I carry out Reballing without special tools?
Rebelling can be done using less expensive tools,you don't have to use a BGA, which is very expensive
The following tools can be used-a hot air gun, SMD vacuum pen and 1-2 metal connectors
Desolater the chip.
This is done by use of 2-metal L form,fix them using 6 mm screws to the motherboard
Once this is done the motherboard is heated for 1-2 minutes in a circular motion the GPU and Motherboard are cleaned up
The Motherboard is cleaned from the solder so that it can have a flat under ground to soldering back the chip.
