How can i change the AD’s color and font on my adsense.
How can I change the AD's color and font on my AdSense. Need to sync them with my site.
Best Answer by Phoeba Walsh
Answered By 5 points N/A #127194
In order to change your AdSense font or color you need to access the Manage Ads section. There you will see all of the ad slots you have created and they are editable. You will only be able to change the font or color after you've created it.
To access the Manage Ads section follow these steps:
  1. Log into your AdSense account.
  2. Go to your admin panel.
  3. Click the AdSense setup tab.
  4. Click manage ads.
Once there:
  1. Select the ad you would like to change.
  2. Scroll down and you will see a Fonts section where you can change the font.
  3. And a Color section where you can choose a color.
The Edit section also allows you to change other things like Corner Style or Format.
I hope this helps.
Answered By 0 points N/A #127196
Dear User,
In order to change color and font you should do this,
Login to your AdSense account. In your account click the AdSense setup tab and click Manage ads. There you will see A listing of a different AdSense ad units that you have managed so far.
You can click edit for each unit. So select the unit you would like to change the font for,
Scroll down and you can change the font. Below is an image.
Ads Display Properties
Same way you can change colors too.
Thank you.
