Sounds lazy? I would like to know how to change all icons Android at once. I am tired of having to change each and every icon separately; it takes time and that is exactly what I do not have. If it is an application that I must install then kindly share the download link as well and a brief note on how to carry it out.
How can I change all icons Android at once?
The icon changer an Android application which has the easiest way to changed your icon. This is the best application that I can give you now. It has a lot of icon pack and the icon can be chosen in the gallery. Click the link to download this icon changer application.
HELLO,
I strongly believe you are looking for that.
Icon Changer for Android
It is a free app on Google Play Store which can give an opportunity of creating customized home screen as your wish.
You can easily choose icons from million of icons from their given icon packs.
Its totally free which make you relax on changing all the icons at a time. Hope you will enjoy it. Download and enjoy now
Icon Changer for Android.
