How can I change icon Mac lion to a com-dll?
I want to change the icons mac lion to my com-dll. With which application can I do that? Has anyone ever used '533soft Icon Changer 4.1119'?
I have a suggestion why don’t you try “Iconeer” it’s a powerful icon builder for MAC. It is well suited with almost all MAC OS X, like MOS 7, MAC OS 8 and MAC OS 9 and also compatible with MAC OS X too. It allows easy making of icons with different sizes and textures. Download it from http://windows9download.net/icon-tools/iconeer-38862.html
Hi there Robert,
Mac icons are made to be unique to each of them so they will stand out among another.
But yes, changing it every now and then is not a bad idea, but it could be a little more work to do.
Anyway, i have here the tutorial for your problem.
This will help you understand how to change and modify Macintosh icons, tutorial can be found here.
Waall Mike
