How can I change it Japanese to English?
My laptop displays Japanese Language.
How can I change it to English.
Because I do not understand Japanese?
To solve this problem follow these steps:
1. Go to your control panel and select Date,Time, Language, and regional options.
2. Then click the regional and language options.
3. Change your default Language setting to English.
And make English your default language.
To understand better on what you have, you must understand on what is written on the label. To be able to read and understand fully on what your doing, you need to be on the right page or planet.
Computers has features that you can activate what language you want to use. It has list of languages pre-installed by the computer manufacturer to customized the computer on the country originated.
To change language originally set by the computer manufacturer from Japanese to any English, you need to follow the steps provided below.
Go to Start, Control Panel
Look for Clock, Language, and Region
Then click on Region and Language
Set the Format on what Language you prefer
Click on the drop down arrow and choose your desired location
Set the Time and Apply the Settings
Go to Location tab and change the location from Japanese to English
Click Apply and OK
Close all the open window and restart the computer if necessary.
