Qaiser
Posted on - 10/04/2016
I am connected to a high-speed public Wi-Fi network, but it provides internet access only for 30 minutes. How can I change MAC address on my Windows 7 PC, so as to access the internet as long as possible?
How Can I Change MAC Address On My Windows 7 PC?
You can change the MAC address on your Windows 7 PC, either by using any free software available online or configuring the property of the network card. You can download the free Technitium MAC Address change from the following link:
https://www.thewindowsclub.com/free-mac-address-changer-tools-windows
OR Follow the following steps to change the MAC address manually:
1. Search for Device Manager in the start menu and open it.
2. Right-click on the network adapter whose MAC address you want to modify and click on its properties.
3. Click on Advanced tab and select Network Address.
4. Enter the value of the desired MAC address without and dashes and click OK.
All the network adapters don’t support this method, so you can use any MAC address changing software.
