How can I change of my monitor’s resolution?
My computer and others icon is so big.
I am change icon and small this. But it is do not work.
So what is solve?
So what is solve?
Dear mithun,
I am glad to help you out. Please go to desktop menu. Then click your right button of your mouse. Then go to personalize. There you will find many options. Go to display settings. Inside display setting you will see many options. There first go to display resolution. Reduce your display resolution.
Then adjust your brightness. After that you go to font size. There you can make small size of your icon. Make any size of icon which you prefer most. Then click to apply button and wait for few seconds. Because it takes few times to adjust with new resolution.
Finally you will find your display adjust way same way to want it.
