Please any one tell me how can i change my static and dynamic IP in Window 7. My system is in intruders control, and they know my IP address. Please tell me how can i get rid from these cyberpunk. I lost my Skype and yahoo passwords.
How can i change my static and dynamic ip in Windows 7?
TCP/IP is the language computer uses to communicate with other computers. To change IP Address follow these instructions. First of all know your IP Address by going to CMD prompt and then type “IP Config”.There you will be able to see your IP Address
Go to Control Panel then click on Network and Internet and then choose Network and Sharing Center then open Manage network connections.
Click on the Local Area Connection to configure your IP Address
Click on the Properties button in the Local Area Connection. It shows the Local Area Connection Properties dialog. click on either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and later click Properties.
For changing the IPv4 IP address settings, follow below instructions:
To obtain IP settings automatically, click Obtain an IP address automatically, and then click OK.
To change the IP address Manually, click on Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address you want to enter(Please check whether the IP address you entered is valid or not).
5. For changing the IPv6 IP address settings, follow below instructions:
To obtain IP settings automatically, click Obtain an IPv6 address automatically, and then click OK.
To change the IP address Manually,click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address you want to enter.
To specify DNS server address settings, do one of the following:
To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
You told that your system is under intruder's control, I suggest you to create a backup of your system files and do the clean installation of OS or Install a new Anti virus software like McAfee or Avast and do the virus removal.
Hi ShaheenIqbal20,
You have asked on how to changed static ip or IP dynamic ip on windows 7. Here is how you can change your IP
For static IP:
Click start, control panel
On network and internet icon, click network status and tasks
On the left side double click change adapter settings
Right click local area networking
Highlight internet protocol Version 4 (TCP/IPv4)
Click properties
Click use the following IP address:
Configure your IP
Example
IP address 192.168.1.1
Subnet mask 255.255.255.255.0
Default gateway 192.168.254.254
Take note your IP addressing must based with the default gateway as this is the IP of your router for you to connect to the internet.
The IP is the last digit of the group. It may be higher or lower IP address ranging from 1-254.
B To change the Dynamic IP
1. Follow step 1-6
2. Click Obtain an IP address automatically
With your problem you better install a spyware remover tool to remove malware or spyware. Go to cnet.com and download a free spyware like hitmanpro. And install this on your PC
Another also to download is ccleaner search this on cnet.com.. this is a registry cleaner this will clean all your history and internet connection traces.. to avoid the intruders come into your system
Another thing is you must turn on your firewall for further protection
Click start , control panel
Click system and security
Check and turn on your window firewall
Another option is to remove unwanted programs in your PC
Lastly you must have an antivirus and it must be updated to remove any virus, malware and spyware in your PC
