How can I change quickly proxy setting on safari?
I need your help. I need to change proxy setting on my safari and as quickly as possible. Please, give me the direction as I can do it easily.
Thanks
Thanks
Hi,Â
Follow these steps to change your proxy setting.Â
1. Launch the safari Application.Â
2. Click on the Edit and then preference.Â
3. Click on the advance and then change settings.Â
4. Now click on LAN setting.Â
5. Click on the check box of Use a proxy server for your LAN.Â
6. In the address fields enter the network name and IP address.Â
7. In the port box enter the proxy server port.Â
8. Click on the advance and specify proxy if you are using different one for SOCKS, SSL and FTPÂ
9. Now click on okÂ
