How can I clone on USB drive for PC with xp?
I want to clone on USB drive for PC with XP. But I don't know how doing it. Please, tell me in detail about it.
Thanks in advance.
Thanks in advance.
There are several programs that you can use to do that. The best program which I can recommend you is the DriveImage XML. It works better compared to the other available software. You can also schedule it to make backups for your drives. Most of all, it is free. Download it at http://www.runtime.org/driveimage-xml.htm.
Another program is the Macrium Reflect. It basically does everything the DriveImage XML does but has a lot more services to offer. The downside is that it costs money but if you have the capacity to buy, I suggest that you purchase it. You can download it at https://www.macrium.com/reflectfree
Notifications
