How can i comment in question
if want to comment in techyv.com then you need to get register in the techyv.com and then got to the question section and see the question then you will be able to start commenting in techyv.com
thank you
Hi, Mahfujrahat! Thanks for your interest in commenting or answering questions and concerns here at TechyV.com. You can surely help a lot of people who are having problems with gadgets, games, applications and a lot more topics.
1) In order to comment or to answer a question of a particular person, you have to first, log in, of course.
2) After logging in, hit the button “Questions”. After which, click “view questions” or the “unanswered” button under Questions.
3) After viewing the question, hit the yellow button box “Submit solution” which is located on the lower right part of the question statement to start writing down your answer.
4) After hitting the “Submit solution” button, a blank box will be available wherein you have to put your answers in there.
5) Lastly, after typing your answer, click the “save” button to submit your answer.
