I have two different word documents with one being the revised Version of another. I want a comparison between both files and, can I track the changes in the revised one after I compare two word documents 2010?
How Can I Compare Two Word Documents 2010?
You can use the legal blackline option while comparing the documents so that you get to know only the dissimilarities between Them and your real files remain intact. To do so:
• Open the files you want to compare
• Under Review tab, click on compare
• Then, choose the original and revised documents under the corresponding fields
• Now, click on more and check the comparison settings you want. Under show changes, choose the level and document type at which you want the changes to appear
. • Click on OK.
