How can i connect my Skype with my iPhone
Skype for iPhone is similar to the program for computers. In order to install Skype in your iPhone, you will need to download the app from the AppStore. To do this you will need to launch iTunes, from there go to AppStore then look for or type Skype. Select the app and start the download. It requires iOS 4.0 or later and at least 22.6 MB of free memory space.
You may also download the file here: https://itunes.apple.com/app/skype/id304878510
This app needs iPhone 3G or above.
Once the app is installed, you may log in with your existing username and password. You no longer need to create a new one.
If you are wondering as to how you will be able to use Skype on your iPhone, there is a way using their Skype for iPhone application.
But before you can use it you need to know first if your phone supports it as well as its other specifications.
Here are Skype for iPhone’s system requirements:
To read the complete instructions on how to use Skype for iPhone visit here
To download Skype for iPhone you may visit here.
