I have a Smartphone using the Android Operating System and I would like to configure it to use AT T Global VPN client for Android so that I can work even when I am on my Safaris. This should be such that I can access the office computer and the computers attached to it on the network. How can I configure this to work? Thanks big time for your assistance.
How can I configure AT T Global VPN client for Android?
Hello Gregory,
For configuring your Android device, you’ll have to follow these steps. Let's begin.
It is called AT&T 3G/4GÂ APN and it works on all unlocked international Android Smartphone, and now I am going to show you how to configure it.
Normally your 3G network is recognized automatically, if it does not you go to Setting>Wireless and Network> go down to mobile network and make sure that data roaming is checked on> go to Access Point Names (APN)> after that select menu and choose «New APN ".
Lead generation and demand generation are two of the business strategies that help businesses grow. It creates a pipeline of interested customers looking to find out more. Lead generation on the contrary, is able...
1....
