How can I connect dameware teamviewer together in one player?
I find that team viewer and dameviewer each has good services. I want to use both. How can I connect dameware teamviewer together in one player?
Hello Corin,
I guess connecting the two applications to work together in the same player will be a little tricky, but you can just install both of them on the same computer and then utilize each of them separately. Since each application may be configured differently and using different ports it may be hard for them to be tied together.
Nicke
Hello Corin,
Team viewer is an internet based remote access software which connects PC to PC very easily and dame ware is also internet base software but a bit advanced and has a commercial remote connection. Both the software has almost same use.
As you have mentioned you find both the services is good so I assume you also know features as well which is not same. Like team viewer has mobile access but dame ware has not, or team viewer doesn’t support email but dame ware support email service. So you can use both of them as per your demand but I'm afraid you can't use it together in one player. Hope this will be a help.
Notifications
