How can I connect to essbase cube via asp.net?
I need your help. I want to connect essbase cube via asp.net. But I don't know how to do it. Please, tell me in detail about it as I'm a beginner in this regard.
Thanks
Thanks
 Hello, Marie
Hope you are fine.
You want to connect your Essbase cube via asp.net.There are several sites where you can get the answer. Among them I am going to give you a link where you will get the process directly without any difficulty. The link is below.
https://ysgitdiary.blogspot.in/2008/09/how-to-connect-to-essbase-cube-via.html.
Here you will get your answer without any irrelevant boring description.
Hope you will get your answer.
Hi Marie Philips,
Oracle Essbase is an Online Analytical Processing (OLAP) Server that provides an environment to deploy pre-packaged applications or to develop custom analytic and enterprise performance management applications for you.
Now with a rapid application development environment, Oracle Essbase enables users to quickly model complex scenarios for their business.
With Oracle Essbase users make a dimensional view of their business and offer their users with the new levels of self-sufficiency to access, navigate, and gives the ability to understand inner qualities or relationships into critical business issues.
Refer to following image and links for more clarification
http://essbase101.blogspot.in/2009/06/essbase-my-first-cube.html
Thanks,
