How can I connect my pc to TV?
I was wondering if I can play games on TV and what do I need. My graphics card is NVidia GTX 470, I think it's sufficient. Thanks
you will need PC , digital tv.VGA connector cable,HDMI cable,mini to RCA AUDIO CABLE.
Check your laptop support double display..Look for VGA output or HDMI output.Adjust display settings in your PC's control panel.
Connecting with HDMI:
Plug it in both the tv and laptop. Switch input source on your television to AV or HDMI. Done.
Connecting with VGA:
Use 15 pin cable and connect one end to TV and one end to PC.On television change input source to VGA or PC.
You may also have to plug in the audio with mini to RCA cables.Plug mini to headphone socket and red and white cables into your tv.
You can now see your PC contents on TV
If you are playing a game on your computer and you also want to view it on your TV, that is possible if your television set supports or has an HDMI cable and your computer also has HDMI port. You cannot use your graphics adapter on your TV if you don’t have a port for it.
With your graphics adapter, NVIDIA GeForce GTX 470, it is possible to connect your TV because it supports HDMI. It has 2 dual link DVI standard display connectors and mini HDMI. See image.
The NVIDIA GeForce GTX 470 supports PCI Express 2.0 with 1280 MB GDDR5 video memory. It supports Microsoft DirectX 11.
