How Can I Contact Microsoft Help And Support. Does Anyone Know?
I cannot reach out to microsoft help and support, if anyone knows how to notify them, do tell. I need some assistance with Microsoft Products.
Hello, to get in touch with Microsoft help and support you just have to follow the steps which are here,
1. Go to Google and then, type Microsoft help and support.
2. Select a genuine link from the page which opens up, it will direct you towards the website. Make sure you open original links or known websites which are reliable and the content is 100% safe. Or You can go to the website directly from here, https://support.microsoft.com/en-in Or You can tweet to them with the help of this link. https://twitter.com/MicrosoftHelps
If you have a problem with your operating system or Microsoft Windows and you need to call Microsoft for support, head down to Global Customer Service phone numbers. The phone numbers to call are divided by region:
To call Microsoft, on the page, click a region where your country is located or belongs to then locate the phone number to call in your country. The number or numbers you can call applies to all Microsoft products. When making a call, make sure to dial or enter the correct country code or region code plus the indicated phone number.
Also, take note of the language supported when calling that number.
