How can I convert and export wav to guitar pro?
I want to export audio files and convert them to guitar pro. How can I convert and export wav to guitar pro? Is there a software to handle the action?
Hi Clotildec,Â
You can convert your files in to guitar pro. For this operation you have to install Audio File Convertor software. For downloading software click this link http://www.nch.com.au/switch/index.html.Â
Now click Download Link (Marked with red Color). After clicking you will be prompt save file. Save files to PC. Once saved, click Installer it will install software and you will able to change your audio files to guitar pro.
Hello Clotildec Hock,
Happy to have a time to help you.
There are lot of Software to convert wave to Guitar pro. Some of them are giving trial versions for free. You can get a trial version from:
But I recommend you to download Guitar Pro 6 full version. It is the most downloaded Software ever from Guitar lovers.
Enjoy it.
Thank you.
