How Can I Convert Autocad Drawing To Pdf?
I am an architect. I make many drawings of the buildings and interiors and used to send to theclient a screenshot of the design. Is there any way that I can convert AutoCAD drawing to pdf?
To convert AutoCAD designs to PDF follow the below.
Step 1: Open AutoCAD software and click on theopen icon to open your drawing.
Step 2: Select the drawing you need to convert and click on open button.
Step 3: Select Save as and select DWG file format when saving the file.
Step 4: Open the link www.zamzar.com and upload the DWG file to convert it to PDF.
Step 5: Click on Download button to download the PDF of the uploaded file.  
Notifications
