How can I convert files from ogg to mp3 ?
I've got some ogg files. I need to convert these into mp3 format.
How can I do it?
Which software is the best in this regard?
Please, tell me in details.
Thanks
How can I do it?
Thanks
Hello Helan,
To convert .oog files, there is a music editing software Fruity Loops producer version i am using which will convert your file to mp3 format. Not only it converts the file but you can edit the complete .oog file and perform any transformation, effects, mixing, your own sound in it. It will provide high quality mp3 output.Â
Why i am suggesting you Fruity Loops is because it does not compress the bit rate due to that it produces the output sometimes better than the original. With the effects on like filters and sound enhancer., you can edit your sound file more amazingly. I am using this software for the past 3, 4 years. It works the best.
If you need my assistance please contact me. I will help you in this situation.
ThanksÂ
If you need a converter to convert your OGG files, here are two media converters you can use. Download Format Factory on MajorGeeks.com. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. This software is a multi-functional media converter that is able to convert both audio and video files.
Supported audio formats include MP3, WMA, AMR, OGG, AAC, and WAV. Supported video formats include MP4, 3GP, MPG, AVI, WMV, FLV, and SWF. It also allows you to rip video DVDs and audio CDs. Note: read before clicking when installing Format Factory to avoid installing unwanted software. This program is bundled with several other unknown applications and tools and can display ads within the application itself as you use it.
You can also use ImTOO MPEG Encoder. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1 GHz or faster Intel or equivalent AMD processor, 256 MB RAM, 50 MB free space, and 16-bit video card.
