halin dan
80 points
Posted on - 05/03/2013
Hallo there!
I need some videos for my phone which plays 3GP videos very well. I have several videos in varying formats and I would like to convert them to 3GP format whenever I am transferring them to my phone. I have been advised to use Koyote soft 3GP for this. How do I go about the conversion process? Thanks big time for your assistance.
How can I convert files using Koyote soft 3GP?
Koyote is a very powerful 3GP converter.
To start converting you must click on ADD FILES and than select where this video is located on your computer. Than you must click OUTPUT PATH and select where you want to save your converted video. Than you must select output format ( in your case 3GP).
Than you can adjust parameters in the right corner. And, when everything is set, you can click CONVERT VIDEO.
