How Can I Convert Folder To Zip Online From Windows?
I want to convert folder to zip online from my Windows machine. I need the fastest way to convert the file from one to another. And process the contents without compressing and formatted as azip file.
Answered By 55 points N/A #150068
To convert a file into zipping you need not rely on any online converterwhereas you can use the inbuilt feature of Windows that lets you convert any file or folder or both into a zip file. It uses basic types of compression but it would be done very quickly. So all you have to do to make a folder converted to zipping is very simple. Right-click the folder and click on send to  compressed zip folder and then the folder will be converted into azip folder and the contents would be transferred to the zip file automatically.  
