How Can I Convert HTML File To Pdf?
I want to convert HTM file to pdf. I have got the HTM file from the internet and have made it download to my desktop. Now I want to convert it to PDF file and email it to my friend.
To convert anHTM file to PDF file you need to get a pdf editor such Microsoft word 2016 so that you can paste the contents of the HTM file to the editor and while saving from the file menu you can specify the format as pdf and the file will be saved as pdf. Now that file you can open your mailbox and while sending the email you can tap on the clip button and select the file and then you can click on the send button hence your PDF file will be sent to the required person.  
Notifications
