Hallo there!
I have several MP4 files in my Mac computer and I would like to convert them to Tivo without any loss of quality of video or audio. Is there an inbuilt application to convert Mac MP4 to Tivo? If not, which application can I best use to fix this? Since I have several of them, a batch converter would do for me in this case. Thanks a bunch.
How can I convert Mac MP4 to Tivo?
Hello Hay
In order to convert from mp4 to Tivo on mac, you need to download MP4 to Tivo converter for mac. This is an easy to use and good software you will be needing. add MP4 files to the program. To convert your MP4 files, carry and drop to the program you have downloaded and installed and choose Tivo MPEG2Â for output format and click convert. It is good and easy to use. You can use this link https://www.iskysoft.com/download.html
