How can i convert my documents to “open office” documents?
I need to convert some pages to open office document. Is there any way to do this? I use windows 7 & office application 2007.
Hi
Converting from Word document to open office, you can open the word document in word and save as an open office document. Here is how you do it; after open the word, go to the control panel and from there select Folder option. Further select the file type from, scroll below to the Document Extension. Highlight your required document and click on Change and scroll below again to word, highlight the Word document then click ok.
If you are referring to Microsoft Office documents, you can do the conversion right within OpenOffice by doing a Save As because OpenOffice can open Microsoft Office document files. Go to the Apache OpenOffice download page and download the latest, Apache OpenOffice 4.1.7. The latest version at the moment supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows 2003 and Windows 2012.
It requires 256 MB RAM, 650 MB free space, and 1024 x 768 screen resolution. For Mac, it supports OS X 10.7 Lion and up and requires Intel processor, 512 MB RAM, 400 MB free space, and 1024 x 768 screen resolution. You also need Java Runtime Environment to use the features of Apache OpenOffice that requires Java.
Go to Java SE Runtime Environment to download the latest JRE. Once OpenOffice is installed, load or open your Microsoft Office documents then do a Save As. This will save the file in OpenOffice format.
