noah jones
Posted on - 07/27/2016
Hello everyone,
I have received a PDF file through an Email, and I feel it contains some errors. I want that file in MS Excel format, i.e. xlsx format. How can I Convert PDF File to Excel using Acrobat Reader?
R. Billy
How Can I Convert PDF File To Excel Using Acrobat Reader?
Follow the steps to transform the PDF File to Excel File.
1) Open the File using Acrobat Reader. 2
) In the right Pane, select the “Export PDF” option.
3) As your Export, Format, choose “Spreadsheet.”
4) Then select “Microsoft Excel Workbook.”
5) Click on “Export.”
You don’t have to worry if you receive a scanned copy.Acrobat Reader Automatically turns on Text Recognition. After that, you have to give a Name to the Excel File. Save the file to the desired location.
