Marlo Brown
10 points
Posted on - 07/07/2011
How can I convert a Photoshop Image to Portable Document File (PDF)?
I have a magazine lay-out which is created in Adobe Photoshop CS3. I want it to compile all pages in PDF; I have heard this can be done through the Adobe Acrobat Pro (as what I have remember the application name). I don’t have this application, and I don’t have the budget to purchase that software.
Is there any other way to do that?
Yes, there are so many way to convert and combine your image to PDF document. You don’t need to purchase another application; you can search for a download on the internet for the solution of your problem.
We have the Open Office Org where Open office Draw and Open Office Write was able to export documents into PDF format. Just paste your image either in Open Office Write or in Open Office Draw one by one until you have inserted all images and format all pages then exports to PDF Format.
Another way is using the Adobe Photoshop CS3 itself. Adobe Photoshop has its built-in tool or function to convert images to PDF format or the Portable Document Format. It is easy and very elementary procedure. Here’s how:
1. Click File on the menu bar then select Automate then PDF Presentation.
2. On the PDF Presentation dialog box, under the source files frame, click Browse button then browse for the image files select all you want to add in your PDF
3. Arrange the Image file according to their page order on the list.
4. Click Save.
5. Key-in your PDF file name then click save.
6. Wait until the automation finished.
