How Can I Convert Rich Text To HTML Using An Online Tool?
Hi all,
I have encountered a need to convert a RTF File to HTML. RTF means Rich Text Format. I have been searching for such a Software but could not find it online. Someone, help me to Convert Rich text to HTML.
Answered By 0 points N/A #113225
I will suggest you to visit this link. http://www.unit-conversion.info/texttools/text-to-html/. This application provides you Two windows. On one window, you have to Input the text, and on the Another window, you will see the output.
To use this, follow these steps.
1) Open the link.
2) Copy the content of the RTF File, and Paste it into the “Input Data” window.
3) Click on the “Convert” Button.
4) You will see all the text in HTML format.
5) Copy the Output Content to a Notepad File, and save it as an HTML file.
