How can I convert xls to htm script?
I need your help to convert xls to htm script. Of course I need any software to do it.
But I don't know which is the best in this regard?
Please, tell me in details.
Thanks
Thanks
There are lots of tools and web sites available for convert XLS files into HTML.
https://document.online-convert.com/convert-to-html is best web site for convert your XLS documents into HTML.
Convert XLS from SOFTINTERFACE is a good software convert XLS files into html script. You can download it form http://www.softinterface.com/Convert-XLS%5CFeatures%5CConvert-XLS-To-HTML-XML.htm website.
Thank You
John major
To convert an Excel spreadsheet to HTML script, first, you have to open the file you want to convert to HTML script and then follow the steps below.
You can also use “Convert Excel Spreadsheet to HTML” software.
