How can I copy and pest in command mode in vim editor?
Hi Marty,
There are many options in vim editor to perform word processing.
This is a very powerful editor in Linux world. If you learn Linux OS you must should learn vim cause you always find this editor in different vendors in Linux.
Ok, here your answers below.
When you open a file with Vim editor and if you want to copy a letter just put cursor at letter then press the key y and 1 one after another that's it.
y1 copy current letter
yw copy current word
yy copy current line
For pest you just need to press the letter “p”
Britnu Salu
The “vi” editor which is pronounced as “vee-eye” is a very strong tool in Linux which can operate in two different modes: the command mode and the insert mode. It is integrated with a massive manual which you can activate using the command “:help” without double quotes after starting the program.
On the other hand, you can also use the commands “man” or “info” as an alternative but it contains rather small information than when using the “:help” command.
The editor always opens in the command mode by default rather than in the second mode which is insert mode. In command mode, you can do tasks like navigate through texts; do search, replace, and or mark blocks as well as other editing tasks. Some of the commands let you shift to insert mode.
Below are some of the basic commands:
