How Can I Copy A DVD To Another DVD- Steps To Follow.
I have a movie on my DVD. I have to give it to my friends. How can I copy a DVD to another DVD? What are the different methods?
Method 1- With the help of FreeDVD.
Step 1: Download FreeDVD and then install it.
Step 2: Load the DVD on your computer.
Step 3: To the hard drive, locate and copy the folder.
Step 4: On the screen of FreeDVD, find and select the folder. Then click Ok. Then select FreeDVD button.
Method 2- With the help of DVDShrink
Step 1: Download and install DVDShrink.
Step 3: Open DVDShrink. Then select the movie through Open DVD.
Step 4: Select the option of Backup. Then OK.
Step 5: from the "Select backup target" dropdown box, select the ISO Image File. Click on OK twice.
