Halton Roy
50 points
Posted on - 04/30/2013
Hallo Guys!
I would like to draw some 3D line graph using Microsoft Windows Excel having plots for A, B, C. I have tried it myself on several occasions but to no avail. Just to make it clear, I do not want to drop something like an image but to plot using some specific figures and have the 3D line graph generated. Thanks.
How can I create a 3D line graph in MS Excel?
Open the worksheet that contains the data you want to plot a graph surface.Il is best not to include header rows or columns in the selection. If you select the headings with your data, the graph can produce strange results .Under area, click 3D Surface. Click the chart area of the chart and the Design tab, in the Chart Styles group, click the chart style to use. If you want to create another chart like the one you just created, you can save the chart as a template by clicking on the Design tab, in the Type group, click Save as Template.
