How can I create acronis drive monitor script ?
The hard disk that I am using does not support S.M.A.R.T . That's why the system will access drive in RAID configuration . So, I want to create an acronis drive monitor script that can be automatically executed according to specified pages . How can I create this custom script ?
Answered By 50 points N/A #193320
Hello, Hall
Hope you are fine. Don’t worry. I think I can give you a solution. Your hard drives do not support S.M.A.R.T. You can create a custom script, and it will execute automatically .Here I give you a link where you find a PDF file to download. It contains a solution for you inside it. As it cannot be attached here so I suggest you to download it.
Download PDF
Hope you will get your answer.
